I have a Forester flywheel, 02 RS pressure plate and unsprung 6 puck disk. Making 300 whp, 320 torque..... Clutch slips when shifting from 3rd to 4th on full power.....
What would cure my ills? Better pressure plate, or 4 puck? Or both.....
In a 1990 Legacy 5speed tranny.
Upgrade to 4 puck (from 6), or get better pressure plate?
douglas vincent
92ss satinsvoice
get a ACT pressure plate.
are you using the forester flywheel to keep the rev's up when you shift?
Andy
94 L n/a 5spd, Rip
91 ss champagne - Rip
88 Leon GL Hatchback - DD
94 L n/a 5spd, Rip
I would just do the pressure plate Doug...a 4 puck will be waaaaaay too on/off for a Subie tranny...
I run a sprung ceramic 6 puck and a Spec Stage 2 PP, and I have no problem hooking up power
Is this the same stock tranny or have you blown any?
douglas vincent
I broke the original tranny with a bad mishift getting into traffic.... Don't every NOT get it into 2nd at full boost and 6500 rpm....
Looks like I will be keeping the 6 puck and getting a better clamping pressure plate.
Innovative Tuning
I have the 4 puck sprung that ACT sells, doug; plus their light flywheel and stiff pressure plate.
being a cable clutch, the pressure plate has noticeable feel increase on the pedal, but it's not too stiff that it wears my leg out or anything; the clutch is like a switch, if you're not slipping it at 2500+ then expect to get your jaw shaken loose, it chatters a lot and takes a lot of feathering to get the car to move at low rpms without excessive chatter.
just thought you'd like to know!
#82 M4 TRSCCA Rallycross
