Codes
Gregmckenna
Codes
well my clutch safety switch went the other night so i got screwing around under there.. spliced them together and it starts now... I had a check engine light an I plugged in this little green harness that apeared to fit toigether... so now its flashing (im asuming this is an engine code) it flashs 2 long.... then 2 short.... so Im guessing a 22?? anyone know what this code is??
You sure? 22 isn't a possible code for our car's atleast.
http://www.troublecodes.net/Subaru/
22 Ignition pulse system (1983 only)/Vehicle speed sensor or circuit or VLC solenoid valve or circuit. (1984 to 1988 carbureted)
Gregmckenna
Gregmckenna
lol, you should fix taht abs though
For me with my car if ANYTHING isn't perfect it bothers me, like right now ITS BOTHERING me! front left CV needs replacement, need to change ATf fluid, need to clean and detail car, need 2 new front fenders(rust) and repaint front and rear hatch and bumper, and a little bondo and front hood. I am going crazy
Gregmckenna
Im pretty much the same way... but the cold permits me from actually doing work... ABS will be a fortune to fix i would suspect... an I really dont know what this engine code is so who knows... my trunck vibrates BAAAAD from my subs ( sounds like hell outside
) I want an exhaust system... I want it lowered... its getting sprayed this spring... just a ton of stuff. dealing with it day by day.. I get my full on tuesday if I can pass... yea I got a 92 SS 5 speed at age 16
IronMonkeyL255
I am not anal about things being perfect, but I HATE having a CEL on.
For me it's 35 - canister purge solenoid. The thing is a PITA to get to, otherwise I would have fixed it long ago.
Rio Red '91 Legacy SS
Gregmckenna
Gregmckenna
Makes perfect sense... except that from my knowledge the kncok sensor retards timing as to compenate for different combustion errors ... in which "ping" would be produced... car runs great... no ping on hills... no ping any time... Ive had the thing at redline Ive never had it at WOT but damn near.... an it never ever has any problems... so I cant see the knock sensor being bad.... is there away a wire has bin knocked off or somthing lol. The only thing I notice is if u give the car a little shot of gas while on fast idle ( I know not a good idea but i never bring it past 3 grand when its warming up)... it will stay at whatever u rev it to for like about 1 second befor it drops back down.. just enough to notice that it has stuck there for a split second... never does this once warmed up
Aha! that website i used sure is outdated :p, get that sensor online here, much cheaper then my dealer(dealer wants $200!!!!) online its $50
https://www.subarugenuineparts.com/oe_parts_cat.html
THe old style of knock sensors crack really really easily, theres a good chance it needs replacing. Both my Legacies needed the knock sensors replced.Gregmckenna wrote:Makes perfect sense... except that from my knowledge the kncok sensor retards timing as to compenate for different combustion errors ... in which "ping" would be produced... car runs great... no ping on hills... no ping any time... Ive had the thing at redline Ive never had it at WOT but damn near.... an it never ever has any problems... so I cant see the knock sensor being bad.... is there away a wire has bin knocked off or somthing lol. The only thing I notice is if u give the car a little shot of gas while on fast idle ( I know not a good idea but i never bring it past 3 grand when its warming up)... it will stay at whatever u rev it to for like about 1 second befor it drops back down.. just enough to notice that it has stuck there for a split second... never does this once warmed up
so the knock sensor can affect, performance, fuel economy, and im hoping idle a little? All these possible or what? Is the one on the site i provided the new one or old? I need to buy one.Splinter wrote:THe old style of knock sensors crack really really easily, theres a good chance it needs replacing. Both my Legacies needed the knock sensors replced.Gregmckenna wrote:Makes perfect sense... except that from my knowledge the kncok sensor retards timing as to compenate for different combustion errors ... in which "ping" would be produced... car runs great... no ping on hills... no ping any time... Ive had the thing at redline Ive never had it at WOT but damn near.... an it never ever has any problems... so I cant see the knock sensor being bad.... is there away a wire has bin knocked off or somthing lol. The only thing I notice is if u give the car a little shot of gas while on fast idle ( I know not a good idea but i never bring it past 3 grand when its warming up)... it will stay at whatever u rev it to for like about 1 second befor it drops back down.. just enough to notice that it has stuck there for a split second... never does this once warmed up
Gregmckenna
IronMonkeyL255
Subarugenuineparts has them for just over $50.
I found them under mechanical catalog>electrical>powertrain control>powertrain control>knock sensor
Gregmckenna
