goodridge brake line help
jefferson
Post by jefferson »
I have been trying to come up with some Goodridge brake lines for a 91 ss and have found an application for the Legacy L and LS. Which of these 2 is the one that fits my car? I haven't been able to find the Goodridge website which I think would help. All I come up with is vendor sites. A part number would really be nice. Thanks.
Jeff
jamal
Vendor
Vendor
Post by jamal »
I would think either will work. wrxbrakes on nasioc would probably know.
Any SS braided lines for the 90-94 legacy will work.
tonflo
Post by tonflo »
The ones I got are Goodridge #24212 & say "92-96 Impreza 2WD-RR DISC w/ ...." The ... means it is printed wider than the label but I think it finishes w/ ABS since I can make out part of the left side of an "A".
Info on back says Goodridge USA Inc, 529 Van Ness Ave., Torrance, CA 90501-1424. 310-618-0909
Or try http://www.goodridge.net/usa/automotive.htm or
l
Also, pick up 2 pairs of speedbleeders & make your life easy. # 3956/639560. 10mm x 1.0
http://speedbleeder.zoovy.com/ or
http://www.russellperformance.com/auto/ ... ders.shtml
'94 Legacy Touring wagon. Quicksilver metallic. WRX rims, Whiteline ALK, SS brakelines, GR2s, alum. coolant tank. Gone, but not forgotten
'99 NSX, Alex Zanardi edition, #11/50. All stock & red 2 go
'05 Corolla XRS
jefferson
Post by jefferson »
Thank you all.
I can now get some lines and flush all that old nasty fluid out of the system. I think it will make quite a difference in these brakes. I don't know why some of the places listed the L and Ls as being different, although they didn't have a part number listed and may have just had the same part for both models. It would have been easy if I could have found the Goodridge site. Thanks for that link.
Jeff
