a few subie noobie questions
m44offroad
Post by m44offroad »
i am new too subarus but nowhere near new to wrenching and i am currently in the process of getting a 90 bc up and running as my daily driver. i also have a 92 bf as a parts car.
my first question is weather the rear door latchs are interchangable between the 2, on the bc the right rear door will not open at all because the latch has been rigged and the bf has a good latch.
my second question is weather the front door glass is interchangable, the bc has some deep scratches in the glass that i cant stand looking at and the bf has clean glass.
and my third and final question is how hard is it to get ahold of ca b pillar trim so i can get rid of the automatic seatbelts
206er
Post by 206er »
I'd bet that both the rear door linkage and the glass will swap over. but Ive been wrong before.
try posting a want ad in the classifieds section and some canuck might pull some from the JY for you. also you could just get some regular manual belts and keep your automatic trim, it wouldnt look that bad.
m44offroad
thanks for the reply, the front windows look the same but i have no clue about the door latch with out getting into the door. the only reason i am looking for the b pillar trim is because the bc i am working on is already missing the passenger side trim. depending on how long it takes to get the motor swapped over i may end up using the trim out of the bf and spray painting it
1990 AWD Legacy LS, 5mt, manual belts and Vikash standalone scantool.
