but im on a public comp and dont have time to look. sorry.
now the side marker lights on these legacys, i think mine should blink instead of just steady glow. i have wired sidemarker lights onto my accord and had them blink and I THINK steady glow also. its been a while since ive drivin my accord so i could be wrong on the steady glow.
now as soon as i replace my rusty front corner sockets i plan to rewire the fender lights to blink, what i need to know is which wires do i use from the front corners to get them to blink. there are two wires in the front signals that go to the center of the socket and one that goes on the outer side of the socket. (ive got a 92 wagon, i know the ones from like 89-90 or so have two wire sockets) now, there are only two wires on the 194 fender light, so what colour wire from the front light will go to what colour wire from the fender light? all i want is it to blink. i dont want to do the trial and error, cut and chop BS i had to do with the accord.
im sure its been aked before...
i did a little bit of searching and i didnt find anything. seriously, it sounds lika ricer thing to do but in my head the little lights just constantly glowing gives them absolutely no reason to be there. i mean hell id rather just remove the bulb in them and make them do nothing than chop the hell outta the wires for a trial and error rewire job. im sure someone somewhere has tried this and either had success or not. pointers, ideas whatever im open for suggestion.
92 Legacy L Wagon AWD MTX
Dirty? Probably.
seriously, who the hell put the cup holder there???
Dirty? Probably.
No, you have to wire them to blink. I retrofitted my '90 with them. There's definitely a thread or two with it. I know Vikash posted which wires they were. Basically you just wire them in with the blinkers. With mine they blink at the same time as the original blinkers when the headlights are off and alternate when they're on. Look it up under side marker lights or something.
ok, ill give a look when i get a chance to im kinda pressed for time right now. i wasnt really sure what to search, ithink i did search side marker lights or something similar to that and didnt come up with anything.
Dirty? Probably.
Dirty? Probably.
