auto to 5 speed question
awdwagon
Post by awdwagon »
Hi
I just picked up an 1991 awd sports sedan turbo. And its an auto :-( (sad) but not to worrie im going to do a 5 speed swap. I have located a 5 speed out of a 93 sedan with 3.90 gears and a drive line. my question is sence this is a hydrolic clutch what will i need for the swap dose anyone have a list of stuff ill need thanks. I know im going to need the
tranny
flywheel
clutch set
gear oil
pedal box
shifter
as far as linkage what am i going to need??? this way i can start geting parts thanks.
Post by 555BCTurbo »
Just Legacy shift linkage...or it may be a good time to do some STi linkage if funds allow...
You will need to also find a clutch master cylinder...
Check out the sticky in this forum on my write-up. It should give you a little more info on the swap.
