OK, the theory is that wheel spacers are bad for wheel bearings.
But is this justified? Has anyone actually had problems with spacers? Or does it just "seem" like a bad idea?
Here's my justification for spacers not being all bad.
Stock offset is 53mm on a WRX with a 16x6.5" rim. The Forester has a 16x 6.5" rim with a 48mm offset. Clearly, a 5mm spacer isn't going to kill the wheel bearings on a WRX, and as far as I can tell, the wheel bearings on my Forester are the same as the WRX.
So if a stock WRX can handle a 5mm spacer, then what can a Forester handle? What is the limit when it comes to offset? There area lots of guys running super low offsets on their Subaru's. I've seen people running 17x7's with 40mm offsets for tens of thousands of miles.
I'm probably going to run a 5mm spacer with extended wheel studs on my front wheels in order to clear my new brake calipers.
Wheel Spacers?
Wheel Spacers?
I think it depends on whether they're on Mike's car or someone else's.
- quasi-mod-o
Hahahahaha Steve
I feel it's appropriate to add that I found that XT6 wheels, which is what I'm on right now, are +45 offset. I thought they were the same as the new-gen cars, but apparently not. And as we all know, since I bitch about it so much, I'm having issues again.
In all honesty though, I've seen more wheel bearing issues with SF Foresters like yours Phil than anything else. Even the mechanic says he does mostly SF Forester wheel bearings. So be careful.
1993 Citroën XM Turbo C.T.
1993 Ford Spectron XL-T
1991 Fiat Croma 2.0T i.e.
Another car, soon to be announced
I need to replace my wheel bearings anyways, 165k puts a hurtin on them.
I plan to run the spacers only until I can find a set of FXT wheels that I can get for dirt cheap. They clear the new 4-pots nicely.
Lezbox... with brakes that could halt the rotation of the earth!
I'm still on the fence. I'll probably do it, but I'm still "iffy" about it.
260+ on mine. Maybe you guys maintain you're cars too much and spoil them. I always found my Subarus never broke when I was broke either.
