Throwing cams in my black legacy
Splinter
Post by Splinter »
I figure while Im doing the timing belt I might as well throw in the delta camshafts I have
Ive got new:
Waterpump
Timing belt
Thermostat
Crank seal
Cam seals (front and rear)
Oil pump o-ring
valve cover gaskets + grommets
is it really as easy as just popping out the old cams and putting in the new? I dont need to adjust anything?
Matt Monson
Post by Matt Monson »
It is really that easy! Ej22's are just dreamy little motors...
ps. get me a pay pal addy and a total. I now NEED that harness...
2000 2.5RS daily driver.
1999 2.5RS w/ 50+ extra whp
Suby Hai!
dzx
Post by dzx »
It's easy, the only difference is you have to put the shims behind the HLA's when you install the cams.
///M
'93 Legacy SS - part out
