MY06 TMIC FTW!
92whitelegacy
MY06 TMIC FTW!
so i picked this up when my y pipe exploded,. got the new IC and the y pipe for 50$ (steal) anyways im gunna fit it up tomorrow should fit tons better and i see no issues at this point ill let yall know how it goes
92 ss 275k+mi, kartboy shifter/bushings, gauges. VRG3 FCD II, NGK I'4s, TDO5-16G 4" dp CAT-less 3"tbe 4.11 gears.
livestrong14
92whitelegacy
man, my turbo makes shit hot, this is the 2nd y pipe ive cause to leak from turbo heat, and theres no fuckin hood on my car right now!. apart from the various 90* angles trying to get a TMIC to work, they suck plain and simple, EBAY has FMIC kits for like 270$ shipped, cheapo but theyll do the job. FMIC FTW!!!
92whitelegacy
dscoobydoo
greg donovan
If the presenting problem is heat from the turbo, I would have to say a heatshield over the turbo would help things.... I certainly plan on putting a heat shield on my car. I might even vent the turbo out of the engine compartment with some sort of simple snorkel.
The turbo is a major source of heat as is the downpipe. If you can eliminate some of their heat especially while the car is sitting (heat rises) - heat soak in the tmic would probably decrease substantially.
Basically, if you are having issues with turbo heat that is not due to a different problem, stopping the turbo from venting into the rest of the engine bay with either a snorkel or a heatshield, might be a good idea.
Danny
Danny
500cc Shifterkart, 125cc Shifterkart, 01 MX5, 93 Legacy Wagon (DIY Turbo)
VF8greg donovan wrote:are you guys (the ones who havent melted anything) on a stock turbo?
Wouldn't header wrap work just as well as a heat shield, you'd obviously have to keep it away from the WG. Might also help keep the exhaust side of the turbo hot. I remember reading a post about it:
http://bbs.legacycentral.org/viewtopic. ... =turbo+hot
Header wrap would be a cheap way to go.
- Findlay
http://www.toolsource.com
dscoobydoo
rallysam
Heat sheild on the turbo is not really the issue. A lot of things cause heat soak besides the turbo. I mean, you shouldn't be melting anything... But, a TMIC is going to suck for drag, autoX, rallyX, etc... regardless of whether you have a heat shield no the turbo.
'00 Impr RS - sold
NuclearBacon
92whitelegacy
Threshld1
Hey can anyone tell me if the cast 90 deg y-pipe elbows between an 03 and an 06 TMIC are any different? Looking at pictures i cant imagine they would be but want to be sure.
EDIT: Buddy of mine who works parts at suburu has confirmed the elbows and y-pipe are the same part#'s as with previous wrx TMIC's
PS. Where are the install pics!!??!!
93 SS 5MT - TD05H-16G, 06 TMIC, Walbro, Zeitronix WB-02 - Scrapped too much rust
91 SS AT
97 Outback - Prodrive quick rack, DMS 40
91 SS AT
Arctic Assassian
No way will a pre-06 y-pipe fit an 06 intercooler. I have a crinkle red cast y-pipe that will not fit my 06 intercooler, but it will fit my 03 intercooler. The inlets into the cooler are spaced about an inch farther apart in the 06.
EDIT: I understand you to be talking about the small cast peices to clamp the y-pipe to. I should take care to read more better. lol
Kickin' it old-school.
NuclearBacon
Arctic Assassian
