FWD to AWD suspension swap two easy questions...I think!
turboleg
Post by turboleg »
So my current setup:
FWD 91 Legacy L (EJ22T swap)
GR-2's for the 91 Legacy
GRP N strut mounts (rear)
Stock strut mounts (front)
2.5 RS coils
2.5 RS top hats (front and back)
Now I'm converting to AWD, I'm thinking:
AGX's
H&R Sport Spring Set
Couple questions I have though:
The AWD is coming out of the 94 AWD wagon. Should I buy the AGX's and H&R's specific to the 94?
Will the GRP N rear strut mounts work for the AWD struts/springs or do I need to go back to the old strut mounts?
- Findlay
http://www.toolsource.com
jamal
Vendor
Vendor
Post by jamal »
yes you'll want 92-94 stuff because I don't think you can get a group N top for a 90-91 (not easily anyway). 92-94 tops are the same as those on a GC impreza. You'll need the upper spring seats as well.
