bracket for slave cylinder
Posted: Mon Mar 19, 2007 5:41 pm
by urabusturbo
I am at the final stages of putting a 5mt into a 92 ss and i am confused as to wheter or not i need a bracket to attach the slave cylender to the transmission or if it just directly bolts up to it. I am using a 95 4.11 tranny.
Posted: Mon Mar 19, 2007 5:49 pm
Are you using a n/a or turbo transmission?
Posted: Mon Mar 19, 2007 8:37 pm
by urabusturbo
i am using a 95 n/a tranny, it seems pretty compatible for the hydraulic setup because the pivot point i needed to change for the clutch fork already had the hole drilled out in it.
Posted: Tue Mar 20, 2007 6:54 pm
I do not know off the top of my head whether the push style n/a clutch setup has a slave cylinder that bolts directly to the trans.
I would venture to say you'd probably need a bracket of some sorts.
Posted: Wed Mar 28, 2007 12:18 am
by urabusturbo
still dont know what to do. please help
Posted: Wed Mar 28, 2007 12:26 am
by IronMonkeyL255
Looking at a few diagrams, I think that the bracket for the cable at the trans end bolts to the same place that the slave cylinder bolts to.
Don't quote me on that, though. This is based off of some general diagrams in my Haynes manual.
Posted: Wed Mar 28, 2007 3:11 am
by urabusturbo
a picture of somones engine bay with a cable style 95 4.11 tranny working with the hydraulic parts off a 94 t-leg would be a HUGE help
