bracket for slave cylinder
urabusturbo
Post by urabusturbo »
I am at the final stages of putting a 5mt into a 92 ss and i am confused as to wheter or not i need a bracket to attach the slave cylender to the transmission or if it just directly bolts up to it. I am using a 95 4.11 tranny.
93 Legacy L- FPgreen, 6 speed, Built motor, hydra, etc
92 L wagon.
01 Forester S-DD
91 mr2 turbo
Are you using a n/a or turbo transmission?
urabusturbo
i am using a 95 n/a tranny, it seems pretty compatible for the hydraulic setup because the pivot point i needed to change for the clutch fork already had the hole drilled out in it.
92 L wagon.
01 Forester S-DD
91 mr2 turbo
I do not know off the top of my head whether the push style n/a clutch setup has a slave cylinder that bolts directly to the trans.
I would venture to say you'd probably need a bracket of some sorts.
urabusturbo
still dont know what to do. please help
92 L wagon.
01 Forester S-DD
91 mr2 turbo
IronMonkeyL255
Post by IronMonkeyL255 »
Looking at a few diagrams, I think that the bracket for the cable at the trans end bolts to the same place that the slave cylinder bolts to.
Don't quote me on that, though. This is based off of some general diagrams in my Haynes manual.
Rio Red '91 Legacy SS
urabusturbo
a picture of somones engine bay with a cable style 95 4.11 tranny working with the hydraulic parts off a 94 t-leg would be a HUGE help
92 L wagon.
01 Forester S-DD
91 mr2 turbo
