Items can be picked up in the Sacramento, CA area.
2002 WRX Front Calipers - $100
These are in great condition. I think I've had these since 2004, they've been sitting in the garage for that long
Carbotech Bobcat #721 Front Brake Pads (1997-2001 2.5RS / 2002-2003.5 WRX Fitment), New in Box - $80
Subaru OEM (1997-2001 2.5RS / 2002-2003.5 WRX Fitment) Front Brake Pads, New in Box - $80
4 Turbo Legacy 15" Wheels with Tires - $75 pick-up in Sacramento Area Only!
The wheels are pretty good condition, only one has any real curbing. These are perfect re-finish canidates. The tires are 'ULTRA HP RADIAL GT.' 195/60R15 M+S All seasons.
Snap-On #SGDP50IRA Screwdriver Set, PHILLIPS, Soft Grip, Red, 5 pcs. New Condition! - $50
Includes: #2 tip, 3 1/2" (SGDP22IR), #2 tip, 9" (SGDP42IRA), #3 tip, 11" (SGDP63IRA), #4 tip, 11 1/2" (SGDP64A), #1 tip, 7" (SGDP31IRA)
Snap-On #SGDS50A Screwdriver Set, Flat Tip, Soft Grip, Red (5 pcs.) New Condition! - $50
Includes: 037" tip, 3 3/4" (SGD1), .032" tip, 7" (SGD2A), .037" tip, 8 27/32" (SGD4A), .046" tip, 10 27/32" (SGD6A), .050" tip, 13 1/2" (SGD8A)
2002 WRX 5MT Transmission: Shredded 2nd gear. Includes the tailshaft housing with center diff installed, input and output shafts with gears (2nd is toast) & bearings, front open diff, case (with all shift forks, speedo stuff, etc), idler shaft, etc. Pre-disassembled for your convenience!! $200
2002 WRX R160 3.90 Rear Diff: Removed in known good condition. If you've seen one, you've seen them all. $100
More pics available upon request-
