I have a few things just sitting around that I should probably get rid of, so I figured I'd offer them to you guys before they go to the junkyard. All these parts are off of my '91 Legacy SS.
~Front brake calipers/rotors/cheap pads. I just upgraded to WRX fronts, so I have no need for these anymore. I tore them down to the bare shell and rebuilt them with new seals and bushings and whatnot about a year ago. Also painted them red at the same time. If you just need the calipers and brackets, I can just throw away the pads and rotors.
~Front and rear swaybars. I just put on Whiteline pieces, so I don't really need the stockers anymore. The rear bar needs new bushings in the bar itself, but any Subaru dealership can get these. I put Energy Suspension PU bushings on the droplinks not too long ago. I also have several more spare bushings I'll throw in.
These are fairly large and awkward pieces, so if you want them I will check on pricing for you. I doubt anyone is close enough to pick them up, but if you want to you can.
'91 Legacy SS parts FS!!
Rio Red '91 Legacy SS
Last call.
These are going to the dump Wednesday if nobody wants them.
