some pictures of the 'future 400 whp" build
douglas vincent
Post by douglas vincent »
Or at least I hope for 400!
NICO
Post by NICO »
nice and clean, love motor pics keep them coming douglas vincent.
Post by 555BCTurbo »
Hehehehehe :twisted:
Splinter
Post by Splinter »
Out of curiousity, why didnt you opt for aluminum pins to get a similar TEC?
douglas vincent
simply because I had the brass laying there.
Post by BAC5.2 »
I'd think the different expansion rates of brass and aluminum would cause problems, don't you?
douglas vincent
Heads are on.
Splinter
Post by Splinter »
Christ on a stick you work fast...
Matt Monson
Post by Matt Monson »
Splinter wrote:Christ on a stick...
I think that's how he died... :shock:
Nice doug...
2000 2.5RS daily driver.
1999 2.5RS w/ 50+ extra whp
Suby Hai!
BAC5.2 wrote:I'd think the different expansion rates of brass and aluminum would cause problems, don't you?
We talked about it a little in this thread
http://bbs.legacycentral.org/viewtopic.php?t=30753
Soarer
Post by Soarer »
Can you fun 400whp safely on an open deck block?
Sold :-( My 1991 Sport Sedan EJ22t 4EAT
WRX Seats, K&N Panel Filter, 3" Turbo Back Exhaust
Current Subi: 1998 Legacy GT Wagon 5sp in the midst of an EJ257 STi swap with 6sp. Woohoo!
206er
Post by 206er »
it is not "open deck" anymore :-D
douglas vincent
All done assembling 95%.
The hardest part has been working on taking a 2.2 phase 1 SOHC cam gear and turning it into a phase 1 DOHC cam gear. Originally I had calculated it to be 22.5% off but it turns out to be more like 27 % off.
But after about 4-5 hours of swearing and 3 cams later, I have a modded cam gear and it installed and only about 1-2% advanced.
The intakes on, most of the little crap is on, and all I really have left for "engine assembly" is to put it on the hoist so I can install the flywheel and clutch!
Waiting
Waiting
Waiting
Clutch show up!
The clutch is supposed to show up on Wednesday or Thursday, which means I have to install it, install the motor, get it running and tuned and race on Saturday....... Possible? Yes. Sane? Probably not.
douglas vincent
ARgghhhh!!!!
So, don't have an oil pickup....
don't have a damn dipstick....
The oil in pipe that attaches to the valve cover is the WRONG size....
Luckily, I fabbed an adapter to the valve cover, and the oil pickup and dipstick are on another motor I am picking up tommorrow.
Splinter
Post by Splinter »
Im guessing you're not a fan of break-in periods? :D
DLC
Post by DLC »
Why have a break-in when he's going out there to break it :)
Legacy Central
douglas vincent
Final build list....
Phase 1 2.5 open deck block with pinned cylinders
Phase 1 2.2 crank
Phase 2 connecting rods
STI pistons
ACL bearings
3 ply metal headgaskets (branded Subaru)
2.5 phase 1 heads mild port and polish - unknown what they are from, but they came with oil outs but no oil in (?)
Estimated compression is 7.2-1
Twin turbo intake manifold
1990 2.2 throttle body
820 cc modded STI 550 sidefeed injectors
3-1 Vortech rrfpr
2.5" intercooler piping
Modded large bore JECS MAF.
Big Ass Intercooler
Borla NA header
Custom uppipe and downpipe
2.5 exhaust for now
T3/T4 Garret/Precision turbo (GT30r equivilent)
Eaton M62 supercharger
Greddy "Trust" Manual boost controller
PerfectPower6 piggyback
Devils Own meth injection kit with progressive setup
3 bar MAP
Perfection brand flywheel (new)
Spec stage 4 clutch with 4 puck (if it shows up in time)
And probably some other crap....
Kelly
Post by Kelly »
Doood, you should totally bolt that thing onto that scooter.
206er
Post by 206er »
you are doing meth now huh... :twisted:
douglas vincent
And just like meth, it costs the most of all the build!
brando
Post by brando »
Well that is just meth'd up! :D
1998 GT
1994 GT
Post by BAC5.2 »
That bigass pulley is hilarious.
douglas vincent
Got the clutch (they shipped me a 6 puck instead of a 4). :evil:
Motor is IN!!!!
Everything is hooked up. I am installing the meth kit right now and taking a break. Installing the custom throttle cable took about 10 minutes longer than putting the motor in! My back is sore!
douglas vincent
It started.
It ran
It makes so much noise.
And leaks oil EVERYWHERE!
I didnt goop the ****ing valve covers like an idiot. And it leaks everywhere.
And it smokes to high heaven
and I am a tad depressed.
In the amount of time it takes to fix the valve covers, I probably could switch motors with the good 2.2......
Argggggggg.
douglas vincent
OK, of course I couldnt just leave it.
I went back to the wagon and started double checking stuff. 2 vacumn lines were off. Had forgot to put the alternator wiring back on (took me something like 20 minutes to find it, haha, I had tucked it into the damn wheelwell!). And then put water in the radiator....
Suddenly I noticed no more noise!
No more air puffing out the damn valve cover breathers...
Still ALOT of oil pouring out the valve covers!
So..... I think I have a 89% chance of this thing working. But have to spend tommorrow morning pulling the damn valve covers off and resealing them. Goop, here I come!
Tired, sore and kinda positive.
