All of it used. And all of it at a good price. 2 cranks because I aquired a phase 1 crank, but found phase 2 rods first.
CP pistons for a 2.35 stroker. Used, supposedly from a motor that spun a bearing. $150, pistons look great. A very minor amount of scuffing on the skirts. Contemplating having the skirts coated. Do I need new rings? Supposedly they only have "startup time" on them.
Pauter rods for a EJ25 Phase 2. Supposedly out of a '01 RS motor. One bearing spun, the rod looks good and can definatly be reconditioned back to new. $150
EJ25 Phase 2 crank. From the same motor as the rods. You can see the scuff from the spun bearing. Might polish out, will for sure clean up at .010 under with a bearing to match. $100, thought this was a bit high, but together with the rods was worth it.
EJ22T block. From the local Pick A Part. Oil pan was smashed, oil starvation ensued. Pistons, rods, crank trashed. No spun main bearings so block is good. $50 (after the fact, block has a large overbore, CP pistons are stock to small overbore, block no good for me. I still have the one in the car to try, should be stock sized)
Gonna be fun. Stock EJ20G going in the car this week or next. Original EJ22T will get torn down soon after. If that block is no good for my pistons, I will try to trade one or both of my EJ22T blocks for a stock sized one.
Once the shortblock is finished, the EJ20G heads and intake will go on the finished block. Really haven't calculated the compression ratio, but it will be close enough to adjust with head gasket selection.
And thanks to all that helped me decide between EJ20G or WRX electronics.
