Bike rad for AWIC rad?
Front, Top, Air, Water.
Splinter
Post by Splinter »
Anyone tried used a radiator from a big bike for their AWIC? My friend has a water-cooled 400CC, and the rad would easily fit in our lower grill, and has the same sized fittings as the AWIC
Im thinking a rad from a 600 or 800 would be ideal
What dimensions is it? I'm sure it'd work fine. My problem was they are typically thicker then the space I had. To do anything more, I'm going to have to notch the bumper beam.
Splinter
Post by Splinter »
Actually I may have found something perfect, a charge cooler from an F150 Lightening
Its like 24x6x3 or something
farfrumwork
Post by farfrumwork »
Yeah, Lightening exchangers - and check ebay and/or mustang forums for a Cobra exchangers. I think they may be the same thing, approx 24x6x3in and should fit nicely in the lower bumper opening.
I was going to source one and try it out, but carefull inspection of the 2 exchangers I have, run in series, led me to keep what the setup I have. They are really nice tube/fin with louvers on the fins to create more surface area and draw air in better. I do not know who makes them however.
As a side note (and pretty worhtless for the discussion, but whatever), for some reason I receive Appliance Design here at work (they send random publications to Engineers even if has nothing to do with their particular industy...), but anyway they had a great article on heat exchangers used in refrigerant/cooling systems - There is some really cool shit out there with very intricate design fin systems and different materials (cool stuff with gangs of plastic tubing)
carry on,
Chad
Old - '93 T-Leg - 14.693 @ 92.68 at 5800ft ASL (Bandimere Speedway)
New - 07 Spec B/stg 2
"bloodstains - speed kills -fast cars - cheap thrills -rich girls - fine wine
i've lost my sense - i've lost control - i've lost my mind" Agent Orange
Post by 555BCTurbo »
A/C condensor ftw!!
My awic doesn't ever get hot...no matter what conditions it is subjected too...and the condensor looks factory...because, well, it is :D
Splinter
Post by Splinter »
Really??
Im surprised the AC condensor flows enough water, since its designed for a gas
It works...that's all I know...
:o
Splinter
Post by Splinter »
How much boost/what turbo?
VF8 18 psi
Nick....it may work....but I can tell you from playing around with the condensor, you could get the same cooling with a much smaller water radiator, and probably have less pressure drop across the radiator. The condensor is EXTREMELY restrictive. It works fine for the intended service, but isn't designed to be used as a radiator.
Legacy777 wrote:Nick....it may work....but I can tell you from playing around with the condensor, you could get the same cooling with a much smaller water radiator, and probably have less pressure drop across the radiator. The condensor is EXTREMELY restrictive. It works fine for the intended service, but isn't designed to be used as a radiator.
Yeah, I don't doubt it...
Honestly, it's the way my car came, and I am not a big "fix what isn't broken" kinda guy...so it works, and therefore I am going to leave it...
Eventually I would truly like to find a proper AWIC radiator out of a Legacy RS and do it that way...
Steeper
Post by Steeper »
I am intrigued by the AC Condenser! Have you ever used one of those IR temp gauges to see how it works?
like after some spirited driving, both sides of the IC and both sides of the AC condenser?
93 impreza wagon
95 v2 STI RA drivetrain
FMIC
002.5 RS bumper and 95 wrx hood
SS 3in TB
Nick's AWIC water was warm to the touch, but not hot, on a ~90 degree day.
I agree with Josh, it works but a proper radiator would be better.
