Moderators: Helpinators , Moderators
Posts: 3335 Joined: Wed Feb 16, 2005 9:40 pm
Post
by 555BCTurbo » Thu Apr 12, 2007 6:46 am
So, I just thought I would inform you all that I successfully anti-lagged my Legacy with my Perfect Power SMT6...
A few guys on here got to see a demonstration last Saturday...
Pictures/movies shall come soon
555BCTurbo on Mon Apr 16, 2007 5:21 am, edited 1 time in total.
douglas vincent
Posts: 3336 Joined: Sun Apr 27, 2003 5:50 am
Post
by douglas vincent » Thu Apr 12, 2007 7:36 am
I thought about trying it tonight Nick, then decided against it! haha.
brando
Posts: 248 Joined: Fri Feb 11, 2005 7:15 pm
Post
by brando » Thu Apr 12, 2007 8:48 am
fireballs are cool!!!!
1998 GT
1994 GT
206er
Posts: 2590 Joined: Wed Jun 04, 2003 4:24 pm
Post
by 206er » Thu Apr 12, 2007 3:31 pm
how does it work?
Post
by 555BCTurbo » Thu Apr 12, 2007 7:51 pm
206er wrote: how does it work?
there are a bunch of small elves that position themselves in the header and fart a bunch to keep the turbo spooled...
Well, actually...it's mostly just a timing modification. Essentially, I retard my timing to 40 degrees ATDC, in the upper part of my rpm range, and just stomp on the gas, and the motor loads up and starts combusting fuel in the exhaust manifold, and begins to spool the turbo, and as a byproduct shoots 4 foot flames out of the exhaust pipe.
206er
Post
by 206er » Fri Apr 13, 2007 1:06 am
sounds like fun.
bet the turbo doesnt think so though...
Post
by 555BCTurbo » Fri Apr 13, 2007 6:05 am
Yeah, I only do it for like 10 seconds at a time...
But no, antilag is not turbo friendly
Carbix
Posts: 235 Joined: Thu May 11, 2006 8:35 am
Post
by Carbix » Fri Apr 13, 2007 6:08 am
im sure thats great for your cat
|====.[Legacy. Central].====|
|=+[Leaving A True Legacy]+=|
douglas vincent
Post
by douglas vincent » Fri Apr 13, 2007 6:17 am
I tried shooting flames out of my cat. The cat ran away.
Post
by 555BCTurbo » Fri Apr 13, 2007 6:20 am
Carbix wrote: im sure thats great for your cat
I don't have any
the car is registered in Salem, Oregon homes...land of no emissions testing
SuperRallyRoo
Posts: 606 Joined: Tue Dec 17, 2002 11:09 pm
Post
by SuperRallyRoo » Fri Apr 13, 2007 6:23 am
Thats why u roll with 2 exhaust systems. The daily kind and the emissions kind.
Legacyless
98 Jetta TDI
206er
Post
by 206er » Fri Apr 13, 2007 7:19 am
douglas vincent wrote: I tried shooting flames out of my cat. The cat ran away.
is that some kind of euphamism?
douglas vincent
Post
by douglas vincent » Fri Apr 13, 2007 7:31 am
SuperRallyRoo
Post
by SuperRallyRoo » Sat Apr 14, 2007 1:13 am
thats messed up...
Legacyless
98 Jetta TDI
biggreen96
Posts: 961 Joined: Sun Nov 23, 2003 4:16 am
Post
by biggreen96 » Sat Apr 14, 2007 8:40 pm
vids!
Post
by 555BCTurbo » Mon Apr 16, 2007 5:21 am
Ask and ye shall receive
Posts: 3043 Joined: Tue Jan 25, 2005 9:14 pm
Post
by 93forestpearl » Mon Apr 16, 2007 7:13 am
You make me wanna rig up another injector and plug in my melon shooter.
Post
by 555BCTurbo » Mon Apr 16, 2007 7:16 am
***There were no additional injectors used in the making of this movie***
brando
Post
by brando » Mon Apr 16, 2007 7:19 am
^ haha
1998 GT
1994 GT
92whitelegacy
Posts: 296 Joined: Mon Sep 05, 2005 7:16 pm
Post
by 92whitelegacy » Mon Apr 16, 2007 6:23 pm
Thats what my car does in between WOT shifts, and just engine braking.
*gurgle gurgle pop BANG(flame)* and repeat
92 ss 275k+mi, kartboy shifter/bushings, gauges. VRG3 FCD II, NGK I'4s, TDO5-16G 4" dp CAT-less 3"tbe 4.11 gears.
Posts: 9026 Joined: Thu Jan 29, 2004 8:47 pm
Post
by BAC5.2 » Mon Apr 16, 2007 7:42 pm
How much boost were you able to build?
Post
by 555BCTurbo » Mon Apr 16, 2007 7:54 pm
6-7 psi...the initial part of the video is just getting the manifolds warm enough, and once it starts popping flames, it is actually building boost...
When I let off the accelerator, I heard the bpv blow off
Imprezive
Posts: 1428 Joined: Wed Jun 22, 2005 4:07 am
Post
by Imprezive » Mon Apr 16, 2007 8:43 pm
you should record a WOT launch.
1988 4Runner RIP
2006 Suzuki DRZ400sm
2007 Miata
1994 Miata
2003 WRX Wagon
2016 Mazda 3
Post
by 555BCTurbo » Mon Apr 16, 2007 10:39 pm
I need to get it set up on a switch first, so I can go between ALS and my normal map...right now I just change it with my laptop...
Once I do that I will do a WOT launch (in the daylight
n2x4
Posts: 1522 Joined: Tue Oct 18, 2005 3:52 pm
Post
by n2x4 » Mon Apr 16, 2007 10:45 pm
Looks awesome!
Don't change maps with your laptop while you're driving. You might lose a floorpan.
By about how much would this shorten a turbo's lifespan?
SUBARUEHS Racing
