Wax My Car Please
Carbix
Wax My Car Please
Post by Carbix »
:-D Well i feel its time to wax my black car back to what it should look like. One prob. I dont know how to wax a car. Im sure i can pull it off fine i just want to know some pointers and what products work best., :-D
|====.[Legacy. Central].====|
|=+[Leaving A True Legacy]+=|
stipro
Post by stipro »
Are you looking to power polish, or just wax?
If you power polish, I would wet sand rough looking areas first w/2000grit. Polish with wool pad, at the slowest rpm, usually 1500rpm. I use #2 meguires cut polish. Then next I use #6 cleaner wax with a foam pad at high rpm.
After its all done I would recommend/use meguires yellow carnuba wax. It has over 80% carnuba in it, which is what you want. Rub the wax on a cool surface, in the shade, perferably after washing it. Let the wax haze, and polish off by hand, with a 100%cotton cloth/diaper.
Hope this helps, let me know if you need more info.
Carbix
Post by Carbix »
wow like a pro man. thanks
stipro
Post by stipro »
Carbix wrote:wow like a pro man. thanks
No worries :-D
