TD05-16g
lgyee4
TD05-16g
Post by lgyee4 »
Deadbolt says that their TD05-16 will bolt up but there will be minor modifications to make it fit properly. Has anyone here done the install of the TH05h-16g with the clocked 90º inlet? I thought I saw that the only real problems were with the cooling and oil lines. Anyone done this installation? pictures?
Thanks for any information.
1993 Turbo Wagon Stock w/turbo back 3"exh, KYB's
92whitelegacy
Post by 92whitelegacy »
I have the deadbolt 16g, with rotated inlet. I love it. The only thing I needed to do was flip the coolant line around. it was easy.
92 ss 275k+mi, kartboy shifter/bushings, gauges. VRG3 FCD II, NGK I'4s, TDO5-16G 4" dp CAT-less 3"tbe 4.11 gears.
legacy92ej22t
Post by legacy92ej22t »
I had their Monster 16G on my '92 SS also. Very nice turbo and pretty easy to install.
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
lgyee4
Post by lgyee4 »
So when I do the swap, what will I need besides the usual gaskets? Any parts I should replace while I'm in ther? The reason I'm asking is because I want to do this over the weekend and there won't be any parts places open.
legacy92ej22t
I'd replace the DP and up-pipe gaskets personaly.
Search, I have a write up about when I did mine. I don't think the pics work any more though.
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
lgyee4
Post by lgyee4 »
Guys, thanks for the insight and advice. I'm a noob with this and appreciate the help. I think I have enough guts to yank the old one out and stuff a new one in. I'll call Jerry and order one tomorrow.
I guess it's like the time I had to install a new window into an exsisting wall. It was tough to plunge the saw into a perfectly fine wall but it turned out OK.
Were you guys able to do this as one person job in a day?
thanks again
asc_up
Post by asc_up »
do you have to upgrade your ecu or anything when you do this conversion?
If you get the clocked 90 deg inlet, it should be a pretty easy install. You'll just need to modify the coolant lines I believe....
As for the ECU upgrade, no you don't need to, however this turbo and an intercooler with higher boost and proper engine management can be a good combo.
FuJi K
Post by FuJi K »
injectors needed, ya?
because I'm just running a simple TD04L w/ TMIC, but keeping boost at 14psi just to be safe because I don't want to go lean. On cools night it creeps to 17psi in middle 4th, and when going into 5th. But boost drops back down when the RPM goes up to 5000rpm. It's just when I shift and the RPM is like 4500 is when the boost creeps to 16-17psi. If it's day time, it just scoots to about 16psi, but holds steady at 14-15psi.
MY99 GF4 5spd DIY Modified
lgyee4
Post by lgyee4 »
The stock (pink) ones should be good enough. I haven't heard many people mention that thier injectors needed to be upgraded too. I could be wrong about that... Anybody?
thanks again Josh, Matt, 92whitelegacy
Yeah....sorry about that....you do need injectors. I'm still running close to stock boost, and maxing out the MAF/Injectors.
lgyee4
Post by lgyee4 »
which injectorsdo you think I need to go with?
The 550 cc/min STi injectors are probably your best bet. You need to switch fuel rails, but that's not too big a deal.
IronMonkeyL255
Post by IronMonkeyL255 »
Legacy777 wrote:The 550 cc/min STi injectors are probably your best bet. You need to switch fuel rails, but that's not too big a deal.
I haven't swapped mine over yet, but I got the rails and injectors for just over $200 (shipping bumped it over 200).
You can find pretty good prices on the stuff on eBay. I think my rails were $40 and came with the original injectors in them.
Rio Red '91 Legacy SS
chochocho
Post by chochocho »
can i use an 04 or 05 sti fuel rail to go with the 550cc/min sti injectors?
no, use 92-94 n/a legacy fuel rails
lgyee4
Post by lgyee4 »
Legacy777 wrote:no, use 92-94 n/a legacy fuel rails
with the 550cc injectors?
yes.....please search....this has been covered before.
chochocho
Post by chochocho »
if we get the td-05 and get the N/A fuel rail and 550 side feed injectors, when should we expect to make changes to the ecu?
Post by 555BCTurbo »
chochocho wrote:if we get the td-05 and get the N/A fuel rail and 550 side feed injectors, when should we expect to make changes to the ecu?
You cannot make use of the extra injection capacity without some variety of method of controlling the fuel trim (i.e. piggyback ECU) as your MAF will still be railed at the same boost pressure with the new injectors as the old.
BXSS
Post by BXSS »
I think some folks are using the grey 440's that came on the factory 16G equipped EJ20G's on stock LSS ECU's without too much drama (check 1/4 mile time post).
I'm sure trimming fuel via some for of EM will unleash a few more donkey-power.
I am personally running a EJ20G with 440's off my stock LSS ECU, & although the car will not break any records it runs pretty good.
94 Legacy SS
96 Impreza OBS
99 Impreza OBS-T
04 Sienna XLE Limited AWD
BXSS
Post by BXSS »
Here is the 1/4 mile post I spoke of before.
http://bbs.legacycentral.org/viewtopic. ... c&start=50
94 Legacy SS
96 Impreza OBS
99 Impreza OBS-T
livestrong14
Post by livestrong14 »
BXSS wrote:I think some folks are using the grey 440's that came on the factory 16G equipped EJ20G's on stock LSS ECU's without too much drama (check 1/4 mile time post).
Agreed! It runs quite well.
91 SS -Carbon Bronze Pearl
EJ257/EJ205 Hybrid
93 Ford Ranger-DD
91 Rio Red SS- RallyX Project
93 AWD Sedan- FOR SALE!
livestrong14
EJ257/EJ205 Hybrid
93 Ford Ranger-DD
