91 Legacy Wagon AWD air suspension conversion
Posted: Mon Apr 23, 2007 3:39 am
by jdonato
Greetings,
This is my first post here so I'll introduce myself.
I'm from a Subaru family, starting with an 84' GL Wagon, then 91' Legacy Wagon AWD, and presently a 2000 Outback Wagon.
My entire family at one time or another has owned 10 different Subaru vehicles. Presently there are 5 operational Subarus in my extended family.
I'm working on the 91' Legacy AWD with failed air suspension.
The dealership replaced all the air bags 6 years ago at a hefty price.
Now I'm looking for a standard strut conversion kit to replace the airbags. Does anyone have any links or knowledge about this conversion. I don't like the option of pulling used suspension parts off a non-air bag vehicle. I'm hoping there is a kit out there that someone here has used and can comment on.
I have a factory manual, Haynes manual, Chiltons manual, garage full of air tools, and a couple sets of jackstands. Now all I need is a source for air bag replacement struts.
Thanks.
jdonato
Virginia, USA
Posted: Mon Apr 23, 2007 5:45 am
by lilevo
Can you just bolt in an entire strut and spring assembly out of a non-air suspension AWD wagon?
I have access to a 91 AWD wagon with struts/springs that I could ship to you if this is the case
Posted: Mon Apr 23, 2007 5:49 am
by 206er
yep thats how it works
Re: 91 Legacy Wagon AWD air suspension conversion
Posted: Mon Apr 23, 2007 5:51 am
by lilevo
jdonato wrote:Greetings,
...Have air suspension, want struts...
jdonato
Virginia, USA
I can ship you a set of assembled springs and struts from a 91 AWD Wagon. PM or email me for details.
Air suspentsion
Posted: Mon Apr 23, 2007 6:19 pm
by jdonato
Lilevo,
PM Sent.
After some creative google searching, I found Strutmasters and an outfit named American Air Suspension that both distribute spring/strut conversion kits to replace the air bags. Does anyone have any comment or experience with any of them?
jdonato.
Posted: Mon Apr 23, 2007 10:27 pm
by Numbchux
AFAIK, there isn't any difference between the air suspension knuckles or strut tops. you shouldn't need any conversion kit or anything. just a set of conventional springs/struts from a gen 1 leggy wagon.
Posted: Tue Apr 24, 2007 12:17 pm
by heartless
in the midst of doing the conversion on a 90 AWD wagon. pretty straight forward if you get the complete strut assembly - tophats, springs, etc. Hardest part is getting the lower bolts loose.
dont forget to disconnect the airlines & electrical connectors that run the air system - there is one plug that runs thru the backside of the strut tower on the fronts that needs to be unhooked and fed thru the hole, and of course the airline on the top. Havent gotten to the backs yet (should be able to get to one tonight after work) so not sure where everything is there yet....
Air supension conversion kit
Posted: Tue Apr 24, 2007 1:30 pm
by jdonato
I've opted to purchase a conversion kit from American Air Suspension, the gentleman I spoke with on the phone was nice and explained its a simple replacement. Seems like I'll answer my own questions. The kit should be here in a couple days. I'll take pictures and report back how it goes.
Jude
Air strut to coil replacement in process
Posted: Fri Apr 27, 2007 2:34 am
by jdonato
Ordered a kit from American Air Suspension .
http://www.americanairsuspension.com/ca ... php?cat=25 on Tuesday morning, 2 big packages arrived Wednesday afternoon. I started the swap today at 1:30
Here is the 91' Legacy mica ruby sitting on flat airbags, there is only 5 inches of ground clearance from the sills so my floorjack wouldn't fit from the side.
The new struts, shorter fronts, longer rears.
Offending air strut
Rear air strut vs rear coil replacement
Right rear replaced and back on ground, fronts still flat
The rear struts took 2.5 hours to swap out completely and torque the wheels. The left front took 1.5 hours which included removing the air compressor and tiny air tank. I quit when it started raining, the right front should take about 1 hour then its time for a test drive
More pics to follow.
Posted: Fri Apr 27, 2007 3:17 am
by DLC
Very cool.
Strut kit completed
Posted: Fri Apr 27, 2007 2:47 pm
by jdonato
After aligning the camber adjusting bolts to the exact position where found and reattaching the front swaybar the air to coil suspension swap is complete. Total time labor about 4.5 hours w/ air tools working off the ground some in the rain.
The rears went up from 12 5/8" to 13 3/4, while the fronts went from a saggy 12 1/7" to 13 7/8". Height measured from centerline of axle to bottom edge of fender "eyebrow".
Test drive went fine, not pops, clangs, or grinding. The ride feels fine- not as good as our 2001 Outback Wagon. At least the 91' Legacy w/ 100k miles is drivable.
Having this product show up in one day sure beats calling around junkyards to see if they have all the right parts (coils, tophats). Now I have an air pump and tank that I could convert to an ARB Locker for another vechile.
Jdonato
Posted: Fri Apr 27, 2007 6:48 pm
by IronMonkeyL255
The struts and whatnot aren't all that hard to source, but I can see what you mean about having everything in a kit.
Air tools make everything SO much better. I need to pick up an air ratchet soon......
