Long story short I think this all started with a leaky axle seal and so I was driving and I got on the highway and I hear this light whirling sound.. I had the radio on so then I muted it.. I was like Ok... (gear oil at home) I was going to try and make it to the auto story.. so I get off the next exit and as I make a right turn the sound got louder... under light throttle.
so I make a left and it's at the same sound level.. and about 3 stop lights later the whole car shakes violent and I hear a metal clunking sound like the front diff has a few broken teeth.. I left the light slow and all.
when I looked at the front diff level it was just below the Line for the Low level is it just me or does the front fluid level go faster then the rear?
moving forward every 5 inches would cause the car to clunk.. In Neutral it was not bad since the pinion gear was not trying to turn the front diff.
so called the AAA tow truck and had it towed to a transmission shop.. I did take some pictures here.. one thing I noticed.. where did the oil seal go on my right front CV joint??
also I have a cracked housing on the Left front.. and also both shafts seemed to push out??
car is a 4EAT
Left front
