So I got into my car and noticed a little pool of oil on my rubber floor mat by the gas pedal. At first I was likem whatever, probably the dude at quickie lube spilled it last week or something. When I was cleaning it up I looked up under the dash just for kicks. There was oil running down the stearing column an dripping off on to the floor!
Is this even POSSIBLE? The only thing I could even come close to reasoning was this:
1. There is an oil feed to lubricate the steering column
2. An oil line for a sensor or guage (unlikely for a stock dash, right?)
Not sure about these cars. But on an old Geo metro some years back, it had a bad seal for the speedometer cable, and the transmission oil would be pumped up the cable by its movement and then leak on your foot.
