The old adding ABS question...kinda
turboleg
Post by turboleg »
So I'm moving forward with swaping my NA AWD drivetrain to my FWD Turbo project car.
My problem is that the AWD is non-ABS and the FWD has ABS. I would like to keep the ABS when I go AWD. Anyone got any ideas what I will need for this?
Will I need entirely new rear AWD rear ABS hubs?
Any part numbers would help.
Thanks!
- Findlay
http://www.toolsource.com
Yes, you will need AWD rear ABS hubs
turboleg
Post by turboleg »
From the schematics I have it looks like every other ABS part will fit together with the ABS hubs, along with my current ABS hardware from the FWD car (rotor/drum setup, wheel speed sensor and the ABS disc). Does that sound right?
- Findlay
Yeah I think so.
