WRX fuel pump work in 93 Legacy SS???
SergeyZ
Post by SergeyZ »
Will a fuel pump from a 02 WRX work in a 93 Legacy SS?
SergeyZ
Post by SergeyZ »
C'mon somebody has to know!
Matt Monson
Post by Matt Monson »
Why? It flows LESS than a stock Ej22T pump...
2000 2.5RS daily driver.
1999 2.5RS w/ 50+ extra whp
Suby Hai!
SergeyZ
Post by SergeyZ »
Oh alright :)
I just installed a walbro! Car is running again :-D
However when doing the timing belt, I broke one of the nipples on the coolant reservoir. Fuck that thing is brittle :evil:
greg donovan
Post by greg donovan »
SergeyZ wrote:Oh alright :)
looks liek you need to read this thread now:
http://bbs.legacycentral.org/viewtopic. ... ght=nipple
96 Impreza L sedan
97 legacy outback limited
00 Impreza RS sedan
SergeyZ
Post by SergeyZ »
^ Thanks !
I got a new problem now... stupid engine light is on. Gotta figure out how to clear the old codes and see which one it is now.
greg donovan
SergeyZ wrote:^ Thanks !
the check engine code is probably on because you got the knock sensor wet. it sits right below the coolant expansion tank.
still a good idea to get it checked anyway.
96 Impreza L sedan
00 Impreza RS sedan
www.surrealmirage.com/subaru/engine.html
