WRX fuel pump work in 93 Legacy SS???
Posted: Sat Apr 28, 2007 9:50 pm
Will a fuel pump from a 02 WRX work in a 93 Legacy SS?
A forum for 89-94 BC-BF(BJ) Legacy Owners and Fans
https://bbs.legacycentral.org/
looks liek you need to read this thread now:SergeyZ wrote:Oh alright![]()
I just installed a walbro! Car is running again![]()
However when doing the timing belt, I broke one of the nipples on the coolant reservoir. Fuck that thing is brittle
the check engine code is probably on because you got the knock sensor wet. it sits right below the coolant expansion tank.SergeyZ wrote:^ Thanks !
I got a new problem now... stupid engine light is on. Gotta figure out how to clear the old codes and see which one it is now.
www.surrealmirage.com/subaru/engine.htmlSergeyZ wrote:^ Thanks !
