Idles rough and backfires. Wont accelerate past 45mph
TheSubaruJunkie
Post by TheSubaruJunkie »
I removed the intake manifold to replace some stupid coolant bypass line. After I put everything back together my car runs like shit. It idles real rough, and when i accelerate it backfires. I cant get it to hardly go past 45mph or 3000rpm.
I checked for vacuum leaks and found none. Im certain I re-connected all the connectors, but im at a loss. The car didnt run this bad before I removed the intake manifold.
-Brian
1983 Subaru GL-10 Brat
1986 Toyota 4Runner
TheSubaruJunkie
Is this something a vacuum leak could cause?
1986 Toyota 4Runner
Bheinen74
Post by Bheinen74 »
it's most likely your timing belt slipped its time. check that and your spark.....
91 Legacy Sport Sedan 4eat
91crx si 165k
91crx Si 40.5k
85 BRAT Gl 140
97 SVX 74k
TheSubaruJunkie
I was pulling a plug wire to remove the plugs and inspect.
The 1st wire I removed, broke apart in my hand. So i went and bought a new set and we'll see if that helps.
I sure hope to god my belt didnt slip.
-Brian
1986 Toyota 4Runner
douglas vincent
Post by douglas vincent »
Make sure you didnt damage or forget to clip back the water temp sensor!
TheSubaruJunkie
Is that the sensor under the alternator? In the center of the block?
-Brian
1986 Toyota 4Runner
douglas vincent
No, its the sensor in the crossover pipe. The Red one, the one that is EASIER THAN CRAP TO BREAK.
TheSubaruJunkie
Crossover pipe? You talking about the section that runs directly under the intake manifold?
Got any pix of this thing? The sensor that is, and where its located.
-Brian
1986 Toyota 4Runner
georryan
Post by georryan »
Would a dying temp sensor make a car idle rough or run rough? I thought it would just mess with your temp gauge. If it does mess with how your car runs I might have solved one of my problems. :)
91 Pearl White Sport Sedan
2014 Volvo S60 T5
18 KTM 1290 Adventure S
97 Toyota 4Runner SR5 - sold
2002 BMW r1150rt-p - sold
2004 BMW r1200ST - sold
2016 BMW r1200RS - sold
Yes the ecu temp sensor makes a huge impact on how the car runs
