So I put in a td04 and hooked everything up except for the boost/vacume lines that manage the boost. I would like to run a hose from the pressure side of the turbo to the wastegate nipple, but I don't know what to hook all of the other lines to so as not to set a CEL or have a vacume leak. For reference, if I get any help, could we use the diagram here, http://www.graphics.cornell.edu/~v/vacuum/ej22t_pcv.gif.
Thanks, Adam.
I am in a time crunch.
Kickin' it old-school.
EDIT - did you want to know about the boost control lines or all the other vacuum tubes?
Can't see the diagram you posted.
'00 Impr RS - sold
Are you trying to just run wastegate boost? If so, just hook the compressor outlet nipple to the wastegate actuator nipple. Cap the boost control solenoid lines but DO NOT unhook it (electrical connector that goes to ECU) or you'll get a CEL and the car won't run right.
Hope this helps as I don't really know what you're asking...
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
