stock recirc w/ FXT TMIC
I am going to use the stock recirc valve with the FXT IC. In the stock location the arrow on it was facing towards the throttle body. On the FXT IC it will it will, of course, be attached to a hose coming off of a 3/4 OD nipple on the two bolt flange on the IC. Will the arrow point to the passenger side(stock inlet elbow to turbo) or towards the drivers side(IC two bolt flange)? Thanks, Homies.
Is this the stock valve for the FXT or the tleg?
