stock recirc w/ FXT TMIC
Posted: Wed May 23, 2007 6:02 pm
by kleinkid
I am going to use the stock recirc valve with the FXT IC. In the stock location the arrow on it was facing towards the throttle body. On the FXT IC it will it will, of course, be attached to a hose coming off of a 3/4 OD nipple on the two bolt flange on the IC. Will the arrow point to the passenger side(stock inlet elbow to turbo) or towards the drivers side(IC two bolt flange)? Thanks, Homies.
Posted: Wed May 23, 2007 6:06 pm
Is this the stock valve for the FXT or the tleg?
Posted: Thu May 24, 2007 12:48 am
by kleinkid
It is the stock Legacy recirc valve.
Posted: Thu May 24, 2007 4:59 am
by 555BCTurbo
IIRC the arrow points to the direction of flow...so it should point away from the intercooler bov outlet
Posted: Fri May 25, 2007 3:10 pm
by n2x4
555BCTurbo wrote:IIRC the arrow points to the direction of flow...so it should point away from the intercooler bov outlet
Correct.
Posted: Wed May 30, 2007 6:43 am
by kleinkid
OK, thanks. When I get to that point, that is what I'll do.
