tranny help
liger86
tranny help
Post by liger86 »
i have a 94 legacy turbo sedan 5sp and i need to change the tranny soon and wanted to know if the tranny from an ej20t bolt on to an ej22t.
Also if anyone knows where i can get the tranny from ej22t or ej20t thanks
Hocrest
Post by Hocrest »
Any Legacy or Impreza 5spd will bolt up. The clutch may be different and the final drive ratio may be different, so you'd also have to swap the rear end.
I'm not sure, but I think that the T-legs had a 3.9?? WRX's use a 3.545 rear, most Leg's and Imp's have a 4.11.
To find a trans you can use http://www.car-part.com/
[size=75]-97 Legacy (ain't never gonna die)
-92 SVX (attention whore)
-86 Brat (more fun than the SVX)
-92 SVX Racer (lightest SVX)[/size]
