Car barely running, NO spark in front 2 cylinders
KC0514
Post by KC0514 »
Car is barely running, will not go over 15mph, no power. It almost appears to be running on 2 cyclinders.
*****(More info in later posts)
Background- 91 EJ22T transplanted into a 93 Impreza. Harness done by ECS. Had a rough idle when i got it back from them, but pulled hard and ran okay. Went to paint shop, then sat 3 weeks and problem started.
I just pulled a plug and it is black and soaked with fuel.
"Better to be a racer for a moment, than a spectator for life."- unknown
"There are only three sports: bullfighting, motor racing, and mountaineering; all the rest are merely games." -Ernest Hemingway
biggreen96
Post by biggreen96 »
hmm paintshop.. maybe an important ground isn't grounding anymore.
KC0514
Post by KC0514 »
I conected the black plugs and pulled the codes last night and this is what I got:
Code 17 Injector #4
Code 21 Water temp
Code 22 knock sensor
Code 52 park switch
How can I get all those codes at once? Is it a clue to a much larger problem? I'm going to do the "battery dance" now and reset the computer.
The car will run, but barely and the motor junps and shakes real violently.
Pull each spark plug wire while the engine's running, and see which ones don't change how the engine is running.
KC0514
Post by KC0514 »
Okay.
There is no spark in the front two cylinders.
I swapped out the coil, no change.
Plus, thsi car is a MANUAL, why would it have a "park switch" code?
Ideas?
Dopey me typo'd the car as an auto. BUT I meant NOT and AUTO.
Check or swap out the ignitor. It's either that, the ECU, or the wiring.
The auto cars have a park signal that comes from the inhibitor switch in the transmission.
KC0514
Post by KC0514 »
I swapped out the ignitor last night with no change.
I'm actually trying to get in touch with Matt at ECS since I can't find where he put the ECU when he wired the swap. I'm thinking it's the ECU, since my previous post meant to say, "the car is a manual, why would I get a park switch code?" My brain wasn't working.
I have an 92 Legacy SS Turbo here, but it's an auto. Will the computer work enough to just test it in the manual 91 car?
I'm ruling out wiring for now, since the car ran decent (not great) after the swap.
I also can not do the "battery dance" to reset the ECU, since the car will not run at idle.
What ECU are you using?
If they're using a turbo legacy ECU, then the AT/MT ident switch is probably wired incorrectly.
You can do the battery dance.....you don't need to let it idle.
You can use your 91 ECU.
KC0514
Post by KC0514 »
The original 91 Legacy MT computer was used.
I tried another AT legacy SS computer and same exact condition.
So to recap.
Tried 2 coils- no change
tried ignitor- no change
tried AT computer- no change
I'm really baffled at this point.
Is the 91 MT computer a turbo legacy ECU or non turbo ECU?
I guess you need to find out what exactly the shop that did the swap did....I've helped out other friends that had a shop do their swap.....and come to find out....the shop did not do things correctly.....and had very little documentation.
KC0514
Post by KC0514 »
The computer in the car is the original 91 Legacy turbo Mt computer that was with the doner car.
East Coast Swappers merged the harness with the Impreza.
The car ran pretty good when I got it back from them. Maybe I'll have it towed back to them.
Thanks for your help.
It's possible one of their wiring crimps got undone.....
legacymax
Post by legacymax »
check for a bad ecu pin for those two cylinders. My car was down for 5 months because of a bad ecu pin. I wasn't getting spark to two cylinders.
-Max
95 impreza Rally car. 3.0 H6
88 Toyota fj62 OME lift.
KC0514
Post by KC0514 »
I just checked the ECU pins, they look fine.
Looks like it has to be a wiring issue, so I give up. I'll have to get a trailer and haul it back to ECS. Ugh.
Thanks for all the ideas guys.
asc_up
Post by asc_up »
any update?
