I have a couple of oil coolers that work with the special water pump that comes on the 91 ej22t.
The set up includes the oil cooler that fits between the block and oil filter, the water pump that has the special feed to send the coolant to the oil cooler, all the lines and misc. fittings. $75 plus $15 shipping to the 48 States.
OEM Oil Cooler set up w/pump, tubing and fittings
