FS: 94' LEGACY SS
Lorilover
FS: 94' LEGACY SS
Post by Lorilover »
'94 SS auto, 240kms (Canada). 4EAT is acting up. Decent body.WRX rims, silver. All accecories work including CD. $1200 CAN[/b]
94 Legacy SS, Silver
DLC
Post by DLC »
email me pictures and I'll host them
Legacy Central
DLC
Post by DLC »
Legacy Central
Innovative Tuning
Post by Innovative Tuning »
What does it need to pass inspection?
Does everything work properly? (tranny aside)
Does the sunroof leak?
When was the timing belt last replaced?
No trouble lights? (CEL , ABS , Air Bag, etc.)
Is it drivable with the tranny acting up? What is it doing?
Thanks,
Mike
Lorilover
Post by Lorilover »
Innovative Tuning wrote:What does it need to pass inspection?
Thanks,
Mike
New tires (if you want to use the tires on it now) Altough I have the OEM rims with good tires mounted on that will be included. Front Left outer tie rod. The mechanicals is sound engine, turbo, emissions control system (no CEL). The Airbag light is on though because some work was done on the ignition switch recently and the airbag wiring had to be disconnected. No the Airbag light will not go off. Maybe this can be easily fixed. The A/C compressor des not work (low refridgerant most likely).
All other accesories are excellent. Sunroof functions flawlessly.
New Subaru timing belt along with engine seals were done in May. Trans went for a dump thereafter. The trans shifts gears good but noise in the tranny pops up above 40kms. It can be driven with the noise however.
Keith.
