Ok, the car was running fine - I have about 100 miles on the car. Was running almost no boost and everything was working perfectly....
I am now getting a serious miss? at anything other than idle.
I can HEAR something grounding out.... I bought new plug wires and installed them and STILL have the problem....
The sound is APPEARS to be located near the throttle body. There is DEFINATELY something arching and grounding out....
I had to move the ignitor to install my tmic. I moved it towards the drivers side and installed it with one screw temporarily....
What else could it be other than the ignitor? This was happening with and without my msd dis2 (which worked perfectly) and with 2 different coils....
Any ideas?
Ignitor dead?
Ignitor dead?
500cc Shifterkart, 125cc Shifterkart, 01 MX5, 93 Legacy Wagon (DIY Turbo)
- quasi-mod-o
Thats not a bad idea.Matt Monson wrote:Have you tried doing it in the dark?
Bheinmen74 - Im pretty sure I read stories on here where one cylinder was down from a dead ignitor....
Anyway, im not going to be able to work on the car for a few weeks.... I just got out of surgery...
I was hoping to have the car finished before my surgery date, but I guess it will have to wait....
Hopefully it will at least be running for the winter so I dont have to drive my miata in the snow
Thanks for the tip - I will have a friend look at the car in the dark!!!
But wouldn't it be 2 cylinders down from an ignitor? Someone correct me if I'm wrong, but our ignitors are 2-channel, with one channel being for the #1 and 2 cylinders, while the other is for the #3 and 4 cylinders. If one channel were out, then that would kill 2 cylinders.
Rio Red '91 Legacy SS
