2005 sti front diff dissasembly ?
stipro
Post by stipro »
Does anyone what socket/special tool is required to disassemble the front diff?. I am reffering to the bolts the hold the crown gear on.
BAC5.2??
Any help would appreciated. thanks.
Post by BAC5.2 »
Good luck!
We locked the shop and all 5 of us went to different local dealers trying to track down the Snap-On guy so we could buy the socket so we could reassemble the tranny. When we found him, he didn't have the tool. We bought a similar tool from a tech at a GM dealership and then had to grind the shit out of it so it would work.
It was a disaster.
I can look in the FSM to see what Subaru tool is needed, but I can't do it today. I might be able to do it tomorrow morning when I get some time, if you can wait.
stipro
Post by stipro »
Yeah I can wait, just let me know when you have the info. Thanks for the reply.
Post by BAC5.2 »
Hmm, for the 05 the FSM just says to loosen the ring gear.
So you just need a standard, thin-walled 6-point socket, not a special Subaru Socket. I remember that's what we had to do with our socket, was grind the crap out of it. But it was an odd size that none of us had, or could find (or wanted to donate to the grinder). At least I think it was an odd size... Otherwise, I don't remember why we drove all over dodge to find a snap-on guy.
Have you tried grinding down an old socket?
The torque on that bolt is only 50.9 lb-ft.
stipro
Post by stipro »
Is there anyway that you could send me a picture of said socket ground to perfection, or lack there of.......
It would really help alot to see what you guys did.
Thankx.
Post by BAC5.2 »
It was thrown away the same day and a correct thin-wall socket was purchased from OUR Snap-on man.
If you have the diff out, it should be easy to eyeball what you need to do to get the nut off.
