5speed swap questions need anwsers
awdwagon
Post by awdwagon »
Ok, so im doing a 5speed swap in my 91 turbo ss. And im looking for parts. I want to swap in a 3.90 manual trans from a 93ss that i have picked up and rebiult. So my questions are as follows
Can i use a wrx drive line and or a wrx pedalbox? will i need to custom cut the firewall to make the clutch fluid rezavar fit?
DLC
Post by DLC »
There should already be a hole for the clutch fluid reservoir. It probably has a rubber plug in it right now.
You probably can not use a WRX driveline, and I'm unsure about the pedalbox, but that'll probably fit.
Legacy Central
awdwagon
more questions
Post by awdwagon »
i cant seem to find the parts im looking for to do the swap.
but i did find this will an sti pedal box etc fit link below please let me know thanks.
http://cgi.ebay.com/ebaymotors/Subaru-I ... enameZWDVW
