CEL codes 17,23,35
1LEGacyUP
CEL codes 17,23,35
Post by 1LEGacyUP »
17-abnormal signal from injector #4
23-abnormal voltage input from air flow sensor
35-purge canister solenoid valve inoperable
The car runs rough intermittently, I have cleared the codes, driven it for ten minutes and all 3 came back.
I'm guessing one of these problems is causing one or both of the others. Does anyone have any suggestions on where to start?
90' Legacy LS
04' wheels
Whiteline 20-24 rear sway,HD mounts, endlinks and adj. control arms
Splinter
Post by Splinter »
Generally, I start by clearing the codes and seeing if they come back up, to clear out the chance that anything was just a fluke or a glitch
1LEGacyUP
Post by 1LEGacyUP »
I forgot to mention that it just starting running very rough Today, but not all the time.
90' Legacy LS
04' wheels
Bheinen74
Post by Bheinen74 »
did your timing belt get changed recently?
if so, it may have stretched recently and skipped.
91 Legacy Sport Sedan 4eat
91crx si 165k
91crx Si 40.5k
85 BRAT Gl 140
97 SVX 74k
1LEGacyUP
Post by 1LEGacyUP »
No, The car only has 114,000 miles on it but changing the belt is coming up soon. If it was a timing problem it would'nt be intermittent.
90' Legacy LS
04' wheels
1LEGacyUP
Post by 1LEGacyUP »
Somebody must know the best place to start, testing,replacing etc
I really need some help guys
90' Legacy LS
04' wheels
Bheinen74
Post by Bheinen74 »
where are you in iowa, i am here too, i think its probably the canister purge solenoid, and i have a few extra ones
91crx si 165k
91crx Si 40.5k
85 BRAT Gl 140
97 SVX 74k
