CEL codes 17,23,35
Posted: Wed Jul 11, 2007 2:50 am
17-abnormal signal from injector #4
23-abnormal voltage input from air flow sensor
35-purge canister solenoid valve inoperable
The car runs rough intermittently, I have cleared the codes, driven it for ten minutes and all 3 came back.
I'm guessing one of these problems is causing one or both of the others. Does anyone have any suggestions on where to start?
