The build will be pretty standard stuff…
EJ22T short block
EJ25 DOHC heads
EJ20G intake
VF24 Turbo
WRX TMIC
440 Injectors
Stock ECU
I’m going to put it back together with the stock 370cc injectors and wastegate boost to start just to simplify the start up debug. They go with the 440s and a MBC and see how it goes with the stock ECU and boost just below fuel cut.
Here’s a few pics to get things started…
Chunks of my up-pipe that jammed in my turbine, didn't seem to harm the turbo, but the thing it so worn out I didn’t see the point of putting it back together… time for the build.
The cylinders look great for 250,000 miles, as long as the bearing journals don’t show me anything worse, it will be a bead hone, rings, bearings.
Head pics just to compare, EJ22T on the left, EJ20G middle and EJ25 right. Look at the difference in valve size between the stockers and the DOHC. Turbo water and oil plumbing will be a direct swap over using the EJ20G parts (drilling and tapping required).
I’m pretty sure I will be going with the intake under the manifold, just have to move the power steering reservoir, then I’ll sweep around to a custom lid on the stock air box.
Mock up, its gonna have to go back into the car to figure out the IC and intake piping.
I'll try to keep this post updated as things move along.
Gary
