Sharpening Up the Steering a Bit (on a modest budget)
Posted: Sat Jul 14, 2007 9:40 pm
It's recently come to my attention in the progression of my driving skill that the steering in my '92 Legacy L isn't quite as sharp as I'd like it to be, nor does it give as much feedback as I'd like. I'm interested in some modest upgrades or tweaks that can be done without breaking the bank (say, $200 total or so? To put it simply I have a pretty tight budget).
Alright, after doing some poking around I've come up with a short list of potential operations:
1. Steering fluid flush
2. Strut tower braces
3. Urethane bushings
4. Alignment tweaks
5. Other tweaks
This is by no means a complete list, I still consider myself a car newbie, so please do add.
Allow me to go over each potential modification in detail so that the practicality can be address more acutely.
I don't know what power steering fluid is supposed to be like normally, but mine is a semitransparent red-ish brown, and it smells really bad, almost burnt. Honestly, I have no idea how or if this can be done by myself, the service manual is of no help. The local Subaru dealer said they don't have the equipment to do a steering fluid flush, but they will in a month and want to charge $80, give or take 10.
I'd like to be able to do this myself, is there a drain valve anywhere? If not, would a normal auto shop have the equipment to do a full flush and fill (since I'm sure they'd charge less)? Either way, what is a quality brand of power steering fluid for me to buy (I'm probably only going to do this once so I want the best)?8
Now I know these would only offer a better feel in hard cornering, but I hear that the cheap eBay braces work 80% as well as the name brands for 15% of the cost, which sounds like a deal to me.
Click here to see the ones I was looking at. These are claimed to be for '94 to '01 WRX STi's, but they should fit, right? This type caught my eye because it's adjustable at each end, but which way should I adjust it, pushing out on the struts or pulling in? I would think pushing out...
I know these with increase NVH (noise vibration and harshness), but that doesn't bother me much. What I am worried about is these causing the steering to fight me hard on somewhat rough road; that might bother me. Click here to see the ones I was looking at, these were the topic of discussion in another recent topic on this subforum although no one gave a detailed account of the handling difference.
4. Alignment tweaks
This was also noted in a recent thread, in which this site was cited. On the site the following setup was recommended; "Front: ~ 3/4 degree negative camber, 1/16+ inch toe-out. Rear: leave stock."
Going through that thread people recommended other settings too, but I thought I'd ask outright, what would be best for occasional aggressive road driving without compromising tire wear? I'm the only driver of the car and I don't mind if it feels 'sporty' sharp all of the time, so long as that isn't extreme.
5. Other tweaks
The only other thing I can think of is adjusting my current generic struts, if possible. Looking at the tops of the struts it seems like at least some aspect of them is adjustable; there's a hexagonal hole that a hex wrench could go in as well as a large nut. I've taken a picture of the front strut tops for you to evaluate:
http://home.comcast.net/~subrosa135/car ... ut_top.jpg
It seems like the nut is just to hold the adjustment of the center part with the hex hole in place, but what do I know, I'm just guessing. Below and out of sight are what appear to be ball bearings around the inside of the rubber part there (maybe I should grease those?).
That's all I've got. Any other ideas or corrections?
4. Alignment tweaks
5. Other tweaks
4. Alignment tweaks
5. Other tweaks
