FS WA: STi TBE
FS WA: STi TBE
STi turboback exhaust
Was custom installed roughly a year and a half ago by Frantic Four, with the necessary extensions to fit a Turbo Legacy sedan. The two extensions are welded on so the o2 bung is in the right location.
Exhaust works great, I love it, it sounds a little more throaty, but still pretty quiet. Just got a deal on a turboXS that I can't pass up!
The exhaust will stay on my car until its sold as I have no place to store a fully assembled exhaust. So, you can see/hear it on my car to decide if you want it.
$250 picked up, I'm in Seattle by University of Washington
'93 Subaru Legacy Turbo Sedan, 5mt
sweeT!
are the bends in the exhaust similar between your sedan and my 1994 touring wagon? do you think they would swap easily
It can fit on your car no worrys at least it should. It already has the adapter built in.
93 Imp wag, 94 Imp wag WRX swap, 99 Imp Sedan WRX swap, 01 Imp Outback Sport, 05 Outback XT, 00 Outback, 98 Outback, 93 Leg touring, 93 Leg wag, 94 Leg wag lifted ej22t swap, 79 Brat 4x4 EA81 4spd d/r swap, 97 Crown Vic lifted
the body style didn't change till 95 pretty sure and it really just has to miss the rear cross member thats all that matters and it does since its made for an AWD car.
oh, and what about the down pipe, does that need to be adjusted or fiddled with to get it to work with this exhaust?
or anything else... would i need to modify anything?
blarg
sedan exhaust is about 6 inches shorter than wagon exhaust, however it'll still clear the rear cross member fine. the lack of length is actually only in the muffler tip. so if someone plans on putting this on a wagon, i'd recommend having the tip extended a few inches.
1991 Legacy L Wagon, FWD to AWD and Automatic to Manual Conversion... then AWD 5M/T N/A to 5M/T Turbo awd swap...
http://www.cardomain.com/ride/879076
oh... so back to me, how much would that cost?eph wrote:sedan exhaust is about 6 inches shorter than wagon exhaust, however it'll still clear the rear cross member fine. the lack of length is actually only in the muffler tip. so if someone plans on putting this on a wagon, i'd recommend having the tip extended a few inches.
