Stock FPR 1:1 Rise with boost?
Hey all, this may be a dumb question, but does the stock turbo Fuel Pressure Regulator raise fuel pressure past the base (without Vac. - 43ish psi) with boost?
94 Legacy SS
96 Impreza OBS
99 Impreza OBS-T
04 Sienna XLE Limited AWD
96 Impreza OBS
99 Impreza OBS-T
It should raise fuel pressure 1 psi for every 1 psi of boost you make.
