which front brakes will fit under the stock 15" rims that use our size rotor but hawk makes the hp+ for?
basically i want to only change the caliper so i can use hawk hp+ front and rear
what front brakes?
bmxkelowna
what front brakes?
BRAKES
Any ~98+ car listed in the sticky that uses 276mm rotors. So like an Impreza RS or many Legacies. I happen to have a set of 98RS calipers and brackets that someone was going to buy but didn't. I'll have to verify what pads they use because for some reason I think they're different than the 02 WRX stuff I put on.
bmxkelowna
