ducting/shroud for a V2 TMIC in a 94SS?
not sure where to begin on this.
i am going to be installing my "slant mount" TMIC onto my SS soon and i am wondering what i should do about making something to direct the limited airflow through the TMIC.
96 Impreza L sedan
97 legacy outback limited
00 Impreza RS sedan
00 Impreza RS sedan
DIY Greg,
I haven't seen any other options with my V2 install
but then again, it's not my problem anymore since I just sold my car yesterday;)
Good luck
Good luck
-Rad
Christine has a new owner, apparently he hasn't abused her enough yet
Understeer is when you see the tree you hit in front of the car, oversteer is when you feel it in the back - Walther Röhrl
anyone have some tips on how to make one or some good terms to search for?
i would imagine that i would want to make some sort of plastic box that is open on the top and bottom.
the trick is how to make it and attatch it so that the hood still closes w/out catching on the TMIC.
96 Impreza L sedan
00 Impreza RS sedan
00 Impreza RS sedan
Here's a link to an old ad, may-be it will give you some ideas.
http://www.rs25.com/classifieds/showpro ... 500&page=1
94 Legacy SS
96 Impreza OBS
99 Impreza OBS-T
04 Sienna XLE Limited AWD
96 Impreza OBS
99 Impreza OBS-T
Trust me, the version 2 inner hood scoops will not fit. I still have one and I tried a couple different ways to make it work.
The ej22t sits way too high for them to fit.
I am having to do a custom unit.
Yes I have too many Subarus
No you can't have one
05 GD-STI
01- RS- Swapped-07 STI
00- GF
05 GD-STI
00- GF
dscoobydoo wrote:Trust me, the version 2 inner hood scoops will not fit. I still have one and I tried a couple different ways to make it work.
do you mind sharing your plans?
96 Impreza L sedan
00 Impreza RS sedan
00 Impreza RS sedan
but i am not using a standard WRX IC. it is the slanted version so a WRX splitter would not line up right.Bheinen74 wrote:remove turbo hood, set aside.
get NA hood
cut hole in NA hood to fit WRX scoop
install the WRX splitter
put bag of ICE on tmic
i think i need to build my own spiltter out of cardboard and then have someone fab up a metal one based off of my cardboard mockup.
96 Impreza L sedan
00 Impreza RS sedan
00 Impreza RS sedan
