Loss of power/stalling before 2nd gear
Posted: Thu Jul 26, 2007 10:16 pm
by gaugedk
Hello all, I have been a long time reader. I have searched this problem but couldnt find much help.
so heres the deal I have automatic 94 legacy turbo. it keeps stalling out or the rpms drop to nothing once the car trys to go into 2nd gear. I try to hit the gas but nothing happens. this lasts for a mile or two and then all of a sudden its fine again. this has happened twice.
I tryed to get the code but its too light out. Ill have to get them tonight.
Any ideas? I was thinking possibly fuel filter, vacume puncture, or sensor problem.
Thanks for your help in advance.
Posted: Fri Jul 27, 2007 2:23 am
by thehookeup
could be a duty solenoid in the tranny
Posted: Fri Jul 27, 2007 2:47 am
by ericem
You getting a check engine light? Wonder if a exhaust converter might need to be replaced.
Posted: Fri Jul 27, 2007 2:09 pm
by gaugedk
My check engine light has always been on since Ive owned the car. The power light flashes when the car stalls out.
I didnt get the code yet, Ill try again today.
Posted: Fri Jul 27, 2007 3:44 pm
by ericem
Posted: Fri Jul 27, 2007 6:03 pm
You need to pull the ECU & TCU codes. Both procedures are on my site under the notes & tips section, engine related, trans related.
Posted: Sat Jul 28, 2007 2:39 am
by gaugedk
Alright I checked the codes and heres what I got
For the existing problem, the power light just blinked I stoped counting after 200 blinks
For the previous problem the power light Blinked 5 times, Long Long Short Short Short.
Thanks guys.
Posted: Sat Jul 28, 2007 3:00 am
by BSOD2600
gaugedk wrote:For the previous problem the power light Blinked 5 times, Long Long Short Short Short.
That would be the Air flow sensor.
Posted: Mon Jul 30, 2007 5:44 pm
No.....that would be the engine revolution signal, since he was checking the TCU.
There is a line going from the ECU to TCU that tells the TCU what the engine rpm is.
Did you also check the ECU?
Posted: Mon Jul 30, 2007 10:56 pm
by gaugedk
Nope I havent checked those yet. as soon as I can get some time Ill post them. Thanks
