Loss of power/stalling before 2nd gear
gaugedk
Post by gaugedk »
Hello all, I have been a long time reader. I have searched this problem but couldnt find much help.
so heres the deal I have automatic 94 legacy turbo. it keeps stalling out or the rpms drop to nothing once the car trys to go into 2nd gear. I try to hit the gas but nothing happens. this lasts for a mile or two and then all of a sudden its fine again. this has happened twice.
I tryed to get the code but its too light out. Ill have to get them tonight.
Any ideas? I was thinking possibly fuel filter, vacume puncture, or sensor problem.
Thanks for your help in advance.
thehookeup
Post by thehookeup »
could be a duty solenoid in the tranny
-93 2.2T (RIP), 93 N/A best car on earth.
-00 legGT, 18" PIAA sport mesh wheels, front/rear Rallitek sways, lowered whitelines, coming soon: 2.5L sti internals, 20g heads P&P, twin charged. motor is almost ready to go in.
Andrew
You getting a check engine light? Wonder if a exhaust converter might need to be replaced.
gaugedk
Post by gaugedk »
My check engine light has always been on since Ive owned the car. The power light flashes when the car stalls out.
I didnt get the code yet, Ill try again today.
You need to pull the ECU & TCU codes. Both procedures are on my site under the notes & tips section, engine related, trans related.
gaugedk
Post by gaugedk »
Alright I checked the codes and heres what I got
For the existing problem, the power light just blinked I stoped counting after 200 blinks
For the previous problem the power light Blinked 5 times, Long Long Short Short Short.
Thanks guys.
BSOD2600
Post by BSOD2600 »
gaugedk wrote:For the previous problem the power light Blinked 5 times, Long Long Short Short Short.
That would be the Air flow sensor.
'11 WRX Limited
'94 TW | R.I.P.
No.....that would be the engine revolution signal, since he was checking the TCU.
There is a line going from the ECU to TCU that tells the TCU what the engine rpm is.
Did you also check the ECU?
gaugedk
Post by gaugedk »
Nope I havent checked those yet. as soon as I can get some time Ill post them. Thanks
