Here is my deal, I'm getting a 2.5 flywheel (from some? Subaru) and I need a clutch to mate to it.
As some of you may already know I'm throwing in an EJ205 with EJ22T heads and a VF11 turbo RUNNING AT STOCK PSI into a 94 Impreza 1.8L AWD.
I'm fairly mean on my transmission but I don't launch it. Since I'm running the above mentioned I expect only 150-190 HP (is this correct?) so can't I use a stock 2.5RS replacement clutch?
The Impreza 2.5RS is ~165 HP stock and their clutch holds fine.
I just don't want an agressive clutch and don't have the experience to try and relearn how to baby a clutch to not harm my transmission.
So will a stock 2.5RS clutch on my setup get me back to work and school for a good while without slippage or exploding?
What clutch?
