DIY front LSD
greg donovan
DIY front LSD
Post by greg donovan »
we are building up our FWD rallycrosser.
we are considering front LSD options.
1. Weld it.
2. Phantom Grip.
3. kaaz, cusco etc.
4. spring from a ford locker rear end.
option one is the cheapest and three is the most expensive. two will eventually wear out and has been known to not work perfect. 4 is something i just learned about and need to do more research.
96 Impreza L sedan
97 legacy outback limited
00 Impreza RS sedan
douglas vincent
Post by douglas vincent »
Been thinking some of the same thoughts.....
greg donovan
douglas vincent wrote:Been thinking some of the same thoughts.....
figured as much based on your post over on NASIOC.
power is worthless if you cant put it down to the ground.
96 Impreza L sedan
00 Impreza RS sedan
n2x4
Post by n2x4 »
greg donovan wrote: power is worthless if you cant put it down to the ground.
You already have AWD, I think you're becoming a traction whore! :lol:
I vote for not welding the front diff, that would be pretty rough on stuff. I haven't heard about the spring thing you mentioned.
SUBARUEHS Racing
greg donovan
i forgot to mention this is for our FWD legacy.
forgot it isnt in my sig anymore.
96 Impreza L sedan
00 Impreza RS sedan
Splinter
Post by Splinter »
Steering a car with a locked front diff would be such a whore
greg donovan
Splinter wrote:Steering a car with a locked front diff would be such a whore
it is really only an issue at parkinglot speeds.
in a rallycross or stage rally it isnt as much of an issue.
96 Impreza L sedan
00 Impreza RS sedan
greg donovan
here is where i learned about using the sprig to make a cheap LSD:
http://forums.neons.org/viewtopic.php?t ... sc&start=0
they learned about it here:
http://www.turbododge.com/forums/f4/f22 ... -copy.html
it is basically a phantom grip w/out the blocks and only costs about 20 dollars rather than 250.
96 Impreza L sedan
00 Impreza RS sedan
Post by BAC5.2 »
The spring sounds cool.
It won't let me register on that site. Can someone register and PM Ghost Neon asking him to take a measurement of the space available for the spring?
I might be willing to give this a shot and remove my front diff to install it. Maybe. I'm nervous about longevity and the last thing I want is a blown front diff.
Post by BAC5.2 »
So can anyone register and PM that guy? If I could get a measurement, I could see if it's even a possibility for our front diffs. If it is, I might be willing to try it.
I also want to know which dealer he's getting them from, and which part number he recommends.
Post by BAC5.2 »
Oh, and I want bolt spacing details on the diff-pin retainer tabs. That just sounds like a good idea. If your punching out the diff pin, every bit helps.
Post by BAC5.2 »
I looked at a front diff today. Definitely not enough room to insert a spring. Sorry :(.
greg donovan
BAC5.2 wrote:I looked at a front diff today. Definitely not enough room to insert a spring. Sorry :(.
that is what i was afraid of.
looks like it is time to bust out the welder.
96 Impreza L sedan
00 Impreza RS sedan
Threshld1
Post by Threshld1 »
Just a thought, has anyone tried moving a rear 91 LSD diff into the front case? Are there any reasons this wouldnt work?
93 SS 5MT - TD05H-16G, 06 TMIC, Walbro, Zeitronix WB-02 - Scrapped too much rust
91 SS AT
97 Outback - Prodrive quick rack, DMS 40
Steeper
Post by Steeper »
the front diff is larger than the rear diff. I was wondering if it was bigger as in the size of a 180 rear diff?
dunno
if it was, I could build the PIMPEST Dtrain with my RA dccd 5mt and the 2 r180 diffs I could get (ones already mine, others a buddys)
93 impreza wagon
95 v2 STI RA drivetrain
FMIC
002.5 RS bumper and 95 wrx hood
SS 3in TB
Arctic Assassian
Post by Arctic Assassian »
the reason it wont work is because the diff are completly different units that work in different ways. One of the techs here tried, and found that there is no possible way to do it without creating a custom pumpkin.
Kickin' it old-school.
