DIY front LSD
Posted: Thu Aug 02, 2007 4:18 am
by greg donovan
we are building up our FWD rallycrosser.
we are considering front LSD options.
1. Weld it.
2. Phantom Grip.
3. kaaz, cusco etc.
4. spring from a ford locker rear end.
option one is the cheapest and three is the most expensive. two will eventually wear out and has been known to not work perfect. 4 is something i just learned about and need to do more research.
Posted: Thu Aug 02, 2007 5:14 am
by douglas vincent
Been thinking some of the same thoughts.....
Posted: Thu Aug 02, 2007 5:29 am
by greg donovan
douglas vincent wrote:Been thinking some of the same thoughts.....
figured as much based on your post over on NASIOC.
power is worthless if you cant put it down to the ground.
Posted: Thu Aug 02, 2007 1:18 pm
by n2x4
You already have AWD, I think you're becoming a traction whore!
I vote for not welding the front diff, that would be pretty rough on stuff. I haven't heard about the spring thing you mentioned.
Posted: Thu Aug 02, 2007 2:10 pm
by greg donovan
i forgot to mention this is for our FWD legacy.
forgot it isnt in my sig anymore.
Posted: Thu Aug 02, 2007 4:02 pm
by Splinter
Steering a car with a locked front diff would be such a whore
Posted: Thu Aug 02, 2007 4:17 pm
by greg donovan
Splinter wrote:Steering a car with a locked front diff would be such a whore
it is really only an issue at parkinglot speeds.
in a rallycross or stage rally it isnt as much of an issue.
Posted: Fri Aug 03, 2007 5:17 am
by greg donovan
here is where i learned about using the sprig to make a cheap LSD:
http://forums.neons.org/viewtopic.php?t ... sc&start=0
they learned about it here:
http://www.turbododge.com/forums/f4/f22 ... -copy.html
it is basically a phantom grip w/out the blocks and only costs about 20 dollars rather than 250.
Posted: Sat Aug 04, 2007 12:58 am
by BAC5.2
The spring sounds cool.
It won't let me register on that site. Can someone register and PM Ghost Neon asking him to take a measurement of the space available for the spring?
I might be willing to give this a shot and remove my front diff to install it. Maybe. I'm nervous about longevity and the last thing I want is a blown front diff.
Posted: Mon Aug 06, 2007 11:23 am
by BAC5.2
So can anyone register and PM that guy? If I could get a measurement, I could see if it's even a possibility for our front diffs. If it is, I might be willing to try it.
I also want to know which dealer he's getting them from, and which part number he recommends.
Posted: Mon Aug 06, 2007 11:42 am
by BAC5.2
Oh, and I want bolt spacing details on the diff-pin retainer tabs. That just sounds like a good idea. If your punching out the diff pin, every bit helps.
Posted: Tue Aug 07, 2007 5:29 pm
by BAC5.2
I looked at a front diff today. Definitely not enough room to insert a spring. Sorry
Posted: Tue Aug 07, 2007 11:21 pm
by greg donovan
BAC5.2 wrote:I looked at a front diff today. Definitely not enough room to insert a spring. Sorry
that is what i was afraid of.
looks like it is time to bust out the welder.
Posted: Fri Nov 09, 2007 4:39 pm
by Threshld1
Just a thought, has anyone tried moving a rear 91 LSD diff into the front case? Are there any reasons this wouldnt work?
Posted: Sat Nov 24, 2007 10:24 pm
by Steeper
the front diff is larger than the rear diff. I was wondering if it was bigger as in the size of a 180 rear diff?
dunno
if it was, I could build the PIMPEST Dtrain with my RA dccd 5mt and the 2 r180 diffs I could get (ones already mine, others a buddys)
Posted: Mon Nov 26, 2007 10:34 pm
by Arctic Assassian
the reason it wont work is because the diff are completly different units that work in different ways. One of the techs here tried, and found that there is no possible way to do it without creating a custom pumpkin.
